I have an intermittent issue with the front of my truck. About every other week when making a right turn sort of tight but not always I fill a klunk or a jump in my front end. Then it will pull to the right. After a bit it goes away or sometimes a hard turn left and it goes way. But it doesn't klunk back when it goes away. Example: It did it again last night. Came up to a stop at an intersection to make a right turn. Made the turn and mid turn I got a loud klunk which felt to be the LF and the truck started to pull to the right. I looked out the window half expecting to see the tire leaned in and it wasn't. Pulled over and looked underneath and found nothing out of place. Started driving again and the pull was gone.
The truck has newer balljoints, all tie rods, and even TTB bushings. I have new tires and they show NO uneven wear and I have done the alignment on it and its damn near perfect. I jacked it up and could get no play out of anything, and had the wife jerk the wheel back and forth while I looked underneath at all the bushings and joints etc.. I have checked the spring mounts at the frame for cracking and everything else I can think of. My only thought is that is could be the steering box.......
This thing is :doh: :dunno:
