1 - 11 of 11 Posts
I have a 2003 6.0 and don't know if I am fighting electrical gremlins or if I am fighting fuel or air issues. I finally got back to trying to figure out what is wrong with the truck and wanted some opinions on where to start. Last I fooled with it, I cranked it, and just let it idle. It was about 20-30 minutes and it's almost like it choked itself down. It was idling fine, cycling fine and not overheating, and slowly the RPM's fell until it fell to a point that it killed itself. I was driving it prior to this attempt and I would slowly lose power, until the point it died as well. There was no pep in the throttle when I got into it. I am starting to think its either a air breathing problem, or somewhere between the fuel sending and top end. The truck does have dirty electrical leads going to the battery and I will be replacing those tomorrow to ensure good quality terminal connections. I have over 200K miles, it has been used as a truck should, and has over heated in past long haul trips, when this happened I would pull over and let it rest, Battery leads do have good connection, voltage is sufficient and stays above 12.4V. Can anyone possibly point me in a direction of where to go? ICP, TPS, fuel pump, idle air controls?
We need data. Sounds like possibly a HPO leak or failing HPOP that gets worse as the oil heats and thins.
ICP%
ICP voltage
IPR
EOT when these readings are taken
FICM V
That will give a start. Otherwise everything is a total guess.
ICP%
ICP voltage
IPR
FICM V
Understood. I'll get ahold of that tomorrow once the suns out and it's not blisteringly cold. I'll post the results ASAP.
If possible maybe a video showing the live data as it is happening. Post video to YouTube and the link back here. If not just post back with the data.
Reactions: jokester00
Staying at 12.4 when the truck is running isn't a good thing.
+1 on PCM data. Also need a thorough scan for codes (ie ForScan is recommended).
2005 F350 Lariat Crew
I want to make sure I heard this right....you idled it for 20 to 30 minutes?
Fuel pressure should be checked -- it sounds like just running out of fuel slowly
Discussion Starter · #8 ·
ICP%
ICP voltage
IPR
FICM V
Any thoughts?
Discussion Starter · #9 ·
Fuel pressure appears to be fine,
scanned it this evening with a snap op scanner and it’s not throwing any codes
What Bismic said. Also is there anything going on with the exhaust, if you still have the cat you could be chocking from a clog there, is there water in the fuel /water separator, how is the fuel filter? Are there any strange smells as it chokes out?
1 - 11 of 11 Posts
