When I purchased my truck (NEW) the card that came with the so called code was wrong. somehow it got switched during delivery with another truck.
Also, for me their was no sticker on the door jamb. so the dealer had to do a scan. So I was told)
Hope you find yours easy enough!
And, FWIW:
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2008 F-Super Duty 250-550 Workshop Manual
GENERAL PROCEDURES Procedure revision date: 01/02/2007
Keyless Entry Keypad Code Programming Printable View (79 KB)
Programming a Personal Code and Keypad Association to Memory Seats and Mirrors (If Equipped)
NOTE: If the wrong code has been entered 7 times (35 consecutive button presses), the keypad will go into an anti-scan mode. This mode disables the keypad for one minute and the keypad illumination will flash. The anti-scan feature will turn off after one minute of keypad inactivity, after pressing the UNLOCK control on the remote keyless entry (RKE) transmitter, or after the ignition key has been turned to the ON position.
NOTE: The factory set code cannot be associated with a memory setting.
Enter the permanent factory keyless entry keypad code.
Within 5 seconds, press the 1/2 button on the keypad.
Enter the new 5-digit keyless entry keypad code. Each number must be entered within 5 seconds of each other.
To associate the entry code with a memory setting, enter a sixth digit to indicate which driver should be set in a memory recalled by the personal entry code:
Pressing the 1/2 button recalls driver 1 settings
Pressing the 3/4 button recalls driver 2 settings
Pressing other keypad buttons or not pressing a keypad button as a sixth digit does not set a driver and will not recall a memory setting
The doors will lock then unlock to confirm the new code is programmed.
Erasing the Personal Codes
Within 5 seconds, press the 1/2 button on the keypad and release.
Within 5 seconds, press and hold the 1/2 button on the keypad for 2 seconds.
All personal codes are now erased and only the permanent factory keyless entry keypad code will work.
