Picked up a couple key fobs for my 03 sd. Tried to program them according to the owners manual i can not get them to work is there a part im missing the truck did not have the fobs when i bought it but does have power locks and windows.
Not sure what it says in the manual. This is how I did it on my truck and it should work for yours.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Hope that help you.
If im not mistaken not all models came equipped with keyless entry. You can check with your vin to see if it came with it or look for the module under the dash. Hope this helps.
Any idea where the module would be or what it looks like size markings. I really want to get this done im tired of searching for keyholes in the dark and scratching my doors up.
Does your truck have an auto function for the headlights? If not, then you don't have keyless entry. They were both part of the same option pack.
Nope no auto lights. Sounds like its going to be fun to swap in
