1 - 13 of 13 Posts
well today i told one of the works at my farm to put 5 gallons of diesel in one of the tractors and he put in kerosene instead:doh:. so now my question is can i run it or do i have to drain the tank?
Thanks ben
Thanks ben
Small amounts of kero are used to winterize #2. So the question is, how much diesel is in the tractor?
kero lacks the lubrication diesel has. Dump some 2 stroke in and you will be fine:thumb:
how much 2 stroke show i put in there 5 gallons of kerosene mixed with probley like 2gallons of diesel in it
it all depends on the motor. I would suck it out, dump it in the truck with as much #2 as you can and then fill the tractor back up. If its some old IDI type motor you should be ok, but why risk it if you dont have to?
its an international 1086 but i think might just drain the tank when i get out of school today
Only the kerosene needs lubricity. So if there are seven gallons and five are kerosene (128ozs x 5gal = 640 ounces of kerosene) bring it up to a 50:1 ratio so 640 X .02 = 12.8 ounces. Add 12 ounces of two-cycle oil. This blend may smoke a bit but better to smoke than run w/o lubricity. Then once empty don't add kerosene again unless you are winterizing the tank's fuel.
thanks for the info but i just drained the tank and i wasnt the one how put it in one of dumb a$$ workers did
Well you took the safe approach. No one's gonna dog on you for that. I've done it before though and added 2 cycle and it ran just fine. For future reference anyways. I like the 2 cycle formula that hheynow put up there. Wonder where he found it...
Discussion Starter #11
well i didnt want to fisk blowing up my tractor
International Threat
Thanks ben
Drain it... kerosene has low lubricity content and can cause injector problems.
It was no problem at all, when you mixed it with the same, or even higher, amount of properly filtered SVO or WVO. And ad just 10 % of diesel for ignation, if that would be a problem.
Using 2 stroke oil is the way for spending money, and is not needed.
I am assuming that your tractor hasn't a common rail.
Greetz, Cp
1 - 13 of 13 Posts
