I had to make a 5 hour drive to Michigan and 1 hour into the trip, I lost cruise control after going through a small town. 4 hours of interstate driving and no cruise sucked. I did not have a CEL, but I checked for codes using my Mini-Max and found the P0087 low fuel rail pressure. I cleared the code ran about 4 hours back to home and lost cruise again. Same code. Now whenever I clear the code, it comes right back. I have no performance issues and the I never get a light (CEL).
I have the Hot Damn (300HP) tune installed and usually run that empty (no load). I run the lower tunes (mild & wild) when towing 5,000#'s.
I imagine the code is related to the expensive to replace HPFP and not the low pressure pump on the frame rail. Anyone have any diagnosing tips? Is there anything I can check before I take it somewhere? I have been running the Hot damn tune for about 800 miles with no issues. The truck has 125K on it, so definately out of warranty. Thanks for any input.
