2005 6.0 Crank No Start - YouTube
Not sure what the problem is. Any help please. When I bought the truck it was down for a leaking EGR cooler, supposed bad starter, and no low pressure base oil. I installed all new parts below and here is the results. Not sure what it could be.
I have a full fuel bowl. I do not get bubbles in the bowl while cranking. Any advice?
IPR / ICP starts at 85% / 3psi and builds up to around 50% / 1500psi.
New Parts list:
STC, standpipes, dummy plugs, oil cooler, oil cooler screen, IPR screen, low pressure oil pump gears, oil pump front cover, oil filters, oil, thermostats, degas bottle, blue spring fuel regulator, starter, two batteries, and welded the EGR cooler (deleted).
New Parts list:
