1 - 7 of 7 Posts
just bought a bunch of stuff for my truck. 7in stack turbo back kit, wicked wheel, speed recalibrator, s&b intake, 3 pod guage kit. i only have a few things in and a only have one question. i started with the exaust. how do i get the old down pipe off. i loosened up the bolt and it does not feel any looser. do you have to beat it off. i am sure i will have a few more question. thank you.
its a v-clamp that holds the exhaust to the exhaust housing. loosen the nut almost till its off and you can then take the t-end of the bolt out of band. there are three pieces that you might need a screwdriver to get loose but after that it should just fall off if you already cut it underneath the truck.
Thank You!!!
Rice Hunter
YUP,,, SAW-ZALL
Dieselis' Maximus
cutting is is easy I put a little PB blast on it and it came off with a screw driver easy.
They are all right. Get er hot, spray her down with PB blaster, and after she cools down enuf to handle, stick a screwdriver in ther and she will almost jump off for ya. Good Luck with all the new toys!
1 - 7 of 7 Posts
