1 - 11 of 11 Posts
2003 Grand Cherokee
Steers hard to left.
Replaced pump.
Any ideas on why it steers hard left?
If turning slow seems OK but when turn fast it gets hard.
Thanks in advance
like the steering wheel is hard to turn?
try checking the u-joints, brakes, ball joints, and TREs and just for anything to bind. might want to jack up the front end and do it in the air you can see if anything is loose that way
Yes it is hard to steer left. I canot find any binding. I am wondering if it could be steering box or maybe a bad line. I have already reaplaced the pump.:dunno:
If you turn the steering wheel slowly it is fine but if you jerk the steering to the left it almost stops and rips the wheel from youre hand and than is smooth.:dunno:
PMR = JUNK
Does it have a stablizer?
Yes it does Why didn't i think of that:doh:
Thanks Jake.
I am going to pull it off and see if the problem still exists.
Meanwhile any other suggestions?
PMR = JUNK
Thanks Jake.
No prob. No other suggestions at the moment.
PMR = JUNK
Get er figgerd out Dale?
duct tape & zip ties
Steering Gear Box maybe binding up or you have a bad valve in it. Which could cause your problem.
Check your steering shaft. Theres a little u-joint right where your steering column comes out of your firewall. My u-joint was breaking when i had to replace mine.
BTW if thats it start hitting the junkyards cuz you dont want to know how much jeep wants for it.
Discussion Starter #11
Thanks everybody for the help:thumb::thumb:
I reaplaced the gearbox and it fixed it.
1 - 11 of 11 Posts
