1 - 20 of 23 Posts
Me and a buddy went to work on installing a intercooler on my truck. Wasnt hard, Was quite fun todo. It went together rather nice.... Having the proper tubes and premade intercooler mounts made it go very smooth.
Well heres some pics..
I was going to take abunch of pictures but fergot that I had the camera:doh:
And thats all the pictures I took, Looks good thru the grill, Ill take some more tomarrow and underhood shots.
Nice. what pipes did you end up using?
Dallas, looks great! Can't wait to see the rest.
Not to get off the subject, but I like your tire / wheel combo, looks like pretty tall tires w/o sticking out too much. What wheel width and tire size do you have?
Hypermax.... They Fit awesome!
Thanks, there BFG 295/75/16 mounted on american racing 16" 'Nitro' rims which are 8" wide if i remeber correctly.
Discussion Starter · #7 ·
Discussion Starter · #9 · (Edited)
Heres a pic of the intercooler thru the grill. I like it!
Tested the intercooler, towed a 20' bertram on a tandem axle trailer with no problems, even did a 10 minute 8% grade which made me limit my speed to 110km/h because egts were at 1200... Pritty good for a generic TS 6 position chip on stock settings with stage 3s and stock turbo. And didnt have the water/meth working for the tow too!
A sharp eye will also noticed I swapped tires... Needed good tread to pull the boat out of the ramp.
Discussion Starter · #11 ·
Looks great... collecting the parts to do mine. Where did you get the premade IC mounts?
I made them.
The top 2 are made from 1/4 thick steel. that are 2" by 3" with two 3/8" holes for bolting the bracket to the body and bracket to intercooler.
bottom ones are 1 square tubing 6" long, there placed right on the frame, where you can bolt them or weld them on. And yes if there welded on you can still remove the intercooler.
Ill try and get some pics of them.
Discussion Starter · #13 ·
Little more power on the top end. Milage went up a tad too.
Of course it was easy with pre-fit pipes:hehe: Looks good man.
What HPOP are your supplying those stage 3s with? Your not worried about starving them or having any problems with stock fuel setup? Thats awesome man.
He is on the stock 15* HPOP:nod::thumb:
HOW? not denying you but thats insane. im running stage ones and throw a code with my 15*
I know what your saying:nod: He IS on stock hpop, fuel system, and turbo.
1 - 20 of 23 Posts
