1 - 7 of 7 Posts
I have a 2018 and since day one I've noticed clanging in the front. I finally found that it was the tie rod ends and drag link. I took it to the dealer and they found it all loose and no grease. They ordered all new tie rod ends and drag link. Well, guess what they installed. They installed the what appears to be factory rod end etc. It is lacking a zerk. fitting and it has no grease and they still clang around. I have another appointment with the dealer on Wed. I'm afraid they will tell me they can't do anything for me and my 2.5 lift and or the tires I just installed caused this. What do I need to do to make all the clanging to go away. Do I need to buy aftermarket in order to get zerk fittings?
Ok, so I grab my steering stabilizer and push it up and down. I assume this is connected to my tie rod ends. When I push this up and down, the tie rod end rotate in the socket whereby I hear a clang, clunk or bonk. This is a metal to metal sound. The issue is there is no grease in the ball joints. Is there a different technology that you do not require ample amount of grease in the ball joints?
I don't have a 2017+ myself. The steering stabilizer is usually attached to the drag link bar. This drag link bar runs from the pitman arm to the upper point on the axle steering knuckle with a tie rod end.
There are tie rods are lower on the steering knuckles (left and right) connected across the front of the axle side-to-side by a single bar (adjuster).
Yes, new technology has been around for quite awhile that has eliminated the "need" for a grease zerk on tie rod ends.
As I stated you can exchange the tie rods for aftermarket ones that require grease more frequently.
Ya well as it turns out, on the 2018 up the steering stabilizer is fixed. It does not move, hence the rod does not move and does not clank the tie rod ends. I have a Carli steering stabilizer and it's allowed full motion. Therefore I will get a clank or two as I drive. Yippy
I’ll take it back to ford and have them repair under warranty. No matter the lift it shouldn’t make that noise. Or check with the company that did your lift.
1 - 7 of 7 Posts
