1 - 20 of 33 Posts
Well I just had my guages put on and I was wondering if 380-400 at idle is normal for my EGTs? :icon_ford:
Standard here.
That seems high compared to mine, but I have an intake and exhaust.
I'm usually running around 260-280*F
Someone will chime in with a little more knowledge
about 300 for me, check my sig. for mods.
I was thinking it seemed a bit high, but the guys at 4 wheel parts where I had it installed said it wasn't?
It might now be all stock, I got my pyro after intake, and exhaust.
well it depends on the tune.. My edge was about 350.. my hypertech on level 3 is about 380 or so
That seems high to me. I WAIT untill it gets down to 300 to even shut it off. It's around 400-500 just cruisin around, 600 highway, 800 towing. And the Michigan COLD it's around 200-300. See sig :dunno:. Maybe our gauges aren't in the same place though who knows.
Well today I made it a point to see what my readings where when driving into work. Here's what I came up with. Idle in drive: 380-400, Cruising at 65: 600-700, and while in park or N it'll go down to 350. This sound ok, or do I need to take it back to 4 Wheel Parts? Thanks guys...
That sounds right to me, Thats about the same temps as mine running a Wild Looney tune :thumb:
Discussion Starter #11
Yea, but I'm stock?
I have free flowing exhaust, intake, and a hot tune.... you have less flowing exhaust, intake, no tune. I think it is somewhat equaling out. Where is the probe mounted?
Discussion Starter #13
The probe is mounted on the driver's side manifold...
topdwg- yup some right.
"Where is the probe mounted?"....seems to be a question that get asked a lot.
Surprisingly,...I've learned that A LOT of people don't have them mounted in the right place.
To get an accurate EGT reading it needs to be in the drivers side manifold...
Discussion Starter #16
It get's up to around 900 when I get on it...
Anyone that has the sensor mounted on the downpipe,...will see around 300-400 degrees cooler.
And if it's mounted on the downpipe- your turbo will be toast before you even realize it....lololol
Discussion Starter #19
LOL, well hopefully the reading is right...
Wait wait wait. do the 6.0's run hotter than 7.3's?? Cause that would explain it.
1 - 20 of 33 Posts
