1 - 12 of 12 Posts
Have a leaking rear axle seal on the right rear wheel of an F-350 4x4. How difficult is that to repair for a backyard mechanic?
Shouldnt be too bad.
Can you give me any tips or direct me to a link or post or something with a decent decription on the repair?
Thanks. Search never seems to bring me many positive results. Apreciate it.
No prob. Hope that is what your after.
pretty easy process.
If I can do it, then ANYONE can do it. :D I did it myself with some hand tools in the driveway. Only thing is, you need the special axle nut socket. I bought mine from Napa for $35.
Done! Thanks for all the help!!!!! Only thing is....... changing the rear end fluid while I'm at it and when I took the rear end cover off there was no magnet????? Isn't there supposed to be a magnet inside the diff cover on a 2006 F-350 SRW???:confused:
nope. The fill plug is likely magnetic, that's it
What did u refill it with?
Discussion Starter #11
I put Amsoil 75w-140 cause it was cheaper than all the other readily available synthetic 75w-140 on the shelf around here locally. Would've used the motorcraft but it was 23 bucks a quart. Amsoil was 16 bucks a quart believe it or not.
It pisses me off how much the motorcraft syn 75w-140 costs.
1 - 12 of 12 Posts
