I had the vgt vanes stick after egr cooler dumped water into the exhaust and blew HG's. Got all that resolved and cleaned the vgt area. Now I am getting MAX boost what seems to be all the time. The truck has no power and acts as if it is starving for fuel. Also LOTS of turbo fart. I thought before I pulled the damn turbo again I'd check to see if the VGT actuator wasnt stuck. Upon removal, the plunger moves fine and all ports are clean so I put a flashlight down the bore to see the shaft and it looks round. I expected to see a lobe or something.:dunno: That is why I am drawn to ask this question. I tried online to see if I could get a schematic of the center section but no luck. Would love to have a breakdown diagram but at the very least some input. Any comments will be helpful. Also have an oil leak coming from that area that im trying to find. I know there are seals/gaskets on the IPR, ICP, Turbo feed & drain tube, HIPOP, and Oilcooler up top and that is where it seems to be coming from. Am I missing a component in the valley?
Mike
Mike
