I'm looking at a 2005 6.0 with 35,000 miles, had it inspected and dealer found some things. Dealer states it was blowing some black smoke after 4 mile test drive, had turbo lag which they could not say if it was the turbo or possibly an injector issue, exhaust leak but did not say where. Also the front brakes are at 9mm and rear at 7-8mm, is this good? What's the thickness on new brakes?
As we were leaving the dealership something broke, dealer said it was the clamp that holds the turbo inlet pipe? And said that a leak in that may have been what was causing the exhaust leak found in the inspection. However the owner is having that problem resolved.
Thirdly the air is stuck on defrost.
My question is from your folks experience with these trucks is this a good truck? Could the broken clamp potentially cause the turbo lag problem? Before it had broken I mean.
I'm completely new to diesels so bare with any rookie knowledge.
Sent from my iPad using Autoguide
