1 - 8 of 8 Posts
I have done some searching around but cant find anything for IPR R&R. Is there a write up or pics of this on here? Got one on the way with the new HPOP. Anything else I could do too while I have it tore down would be helpful. Thanks!
Discussion Starter #2
:bump::bump:
are you replacing the ipr in the old hpop in the truck?
fairly straight forward. I've never used a socket on one (never changed it in the truck) but it is atleast 1" or 1"1/4 deep well socket that you will need. There is a small locking nut on the back of the ipr (9/16's i believe maybe 5/8) take that off and remove the spacer and the magnet (after unplugging) and remove ipr with deep socket.
If you plan on cleaning your IPR, and reusing it, I wouldn't do it. Just buy a new one and clean your old one and keep it for a spare. They are too touchy to mess with... and very small parts...
Make sure you dip it in oil before you install it...
Use a Kolbalt 1 1/8" socket. its long enough to get a ratchet on there even! perfect for that job. bought one specifically for that.
I have the pump and the IPR ordered and will be here at the same time. Where Exactly is the IPR located?
I need money...
As your looking down in your engine bay, just to the right of the fuel bowl and down,you will see your 2 HPO lines off of the pump. A bit below that is your IPR. You should be able to see a gold colored shaft and a small harness that goes to it. It will also have an odd looking nut at the end of it!!
1 - 8 of 8 Posts
