Addicted to Diesel
i recieved my o-ring kit for the IPR and i was wondering for those that might have replaced or might know is the square shaped ring supposed to be split. kinda making it look like a lock washer if you separated it a little?
Addicted to Diesel
Discussion Starter · #2 ·
bump.........
John Wood Nut Swinger
Yes it is supposed to be split. When you pull the old one out, you will see where it goes. I would have to go pull my old one to tell you where but it is a correct part that you have.
Addicted to Diesel
okay thanks. just wanted to be sure before i opened it up. i figured i could just pull the ipr and figure it out, but i knew i could get an answer here first.
