Since the zoodad is used for incoming air for the air intake...
Could you do a zoodad mod on the left side if you were using the ipr cooler, in order to cool off the oil a little better ?
Joe
Don't see why not. But I don't see it making much of a difference.
Does the engine bay get that much cool/fresh air that this would not help ?
The way I see it, the cooler would be getting blasted with fresh air directly from the front of the truck. I would venture to say that it would greatly help, unless i severely underestimate the amount of fresh/cold air that the bay gets while driving. Or maybe the area that this cooler gets relocated to is soooo much better than the stock location that a little more cool air does not make a difference.
Joe
Me either. The cooler is designed for water/oil interaction, not air. If it was designed with fins like the tranny cooler or the BPD oil cooler then air would be a big help.
