Does anyone have any pointers on how to install the rear screw on the IPR coolant filter manifold without taking the turbo off. I spoke to Vince several weeks ago and he said it could be done, but I'm having no luck.
I just put mine on, but I had the oil cooler cover off the truck when I did it. You can usually get torx bits to go at some pretty good angles tho.
When I did mine, I used a racheting 1/4 wrench and a regular torx bit. Took forever because the wrench had a very small arc of movement. If you have a good bit driver and a semi long torx bit, it should be easier.
Thanks for the reply. I thought of the ratcheting 1/4 in with a bit but haven't located one until today. Of course now I'm leaving town for 2 weeks. (fly fishing)
