1 - 20 of 47 Posts
Hello Powerstroke.org members. I'm proud to be a sponsor and member of this forum. I spent my career as a Ford Motor Company Senior Engineer working on many vehicle programs including F-Series Power Stroke Super Duty Trucks as well as testing and analysis of competitive trucks.
I here to assist you with all your technical and vehicle questions. I will use my experience to assist you to improve the performance and durability of your trucks and other vehicles and equipment.
I am currently the largest AMSOIL Distributor Nationwide and am passionate about AMSOIL Synthetic Lubricants and Filtration products. I first learned about AMSOIL while working as an Engineer at Ford alongside Roush Racing Engineers and learned that Roush uses AMSOIL in their race cars. I used AMSOIL products for many years before deciding to become an AMSOIL Dealer and then in 2003 I left my Engineering position at Ford in order to pursue my AMSOIL business full time.
Thank You, Dave Mann
WELCOME Dave! Pleasure to have you on board with us. :)
Welcome to the org. Glad to have you aboard , Maybe you could help us 6.4l guys with our fuel mileage issue.:ORG welcome:
Welcome to Powerstroke.org
:welcome1::welcome2::welcome1::welcome2::welcome1::welcome2::welcome1:​
Welcome to the ORG.
I am sure you will a big help in here..
Thanks for joining us at the ORG!! Great to have you onboard:thumb:
:ORG welcome:​
:welcome1::welcome1::welcome1:
I'v been using Amsoil for 25 years or more.
I have ben meaning to call Amsoil about this question, since your here I'll ask you.
I have a spinner bypass on a Cummins 855, 45k hrs on the engine and i have gotten no carbon out of the filter. With the engine running, i take the cap off and see the thing spinning faster than I can see, . Do you why carbon or other crude is not settling out?
:ORG welcome::beer::drinking4::beer::ORG welcome:​
All Amsoil here. :thumb:
Discussion Starter · #14 ·
6.4L Fuel Economy
Thanks, what is your MPG now? The 6.4L's are not much better than some of the 6.0's due to the additional emissions equipment; ie the DPF and the EGR system. My 6.0L gets 11.4 on average in summer and less in winter, while some other build dates and years average 14-16 and some can get closer to 20, however there is wide variance depending on options, wheel/tire size, modifications, PCM, new engineering releases/injectors, electronics etc during a particular production model year etc.
Discussion Starter · #15 ·
That is not an AMSOIL manufactured unit. AMSOIL does not offer spinner filter systems, just singe and dual remote by-pass units utilizing valve blocks with spin-on threaded by-pass filters that remove soot and water.
Most likely the depends on the micron rating of the spinner as to what particle size soot particles that it traps. I'd recommend contacting the manufacturer of that unit to make sure it is functioning properly.
The spinner is a centrifuge., Several of my friends have the same setup and get alot of soot, but their using dino oil. It's spinning fast and oil is going through it. I am taking it off and putting an amsoil bypass filter on instead.
Thanks for the responce.
Welcome to the ORG! Great to have you here sponsoring the site, Dave!
:welcome1:
I have been reading that AMSOIL is not good for a 7.3 Powerstroke. I have a 1997 F250 7.3 Powerstroke with 76,000 miles on it. I want to switch to 15 w 40 Synthetic oil in my truck will this be ok.
1 - 20 of 47 Posts
