I have the following electrical problem. Hopefully someone can give me some advice on solving this:
Door open warning on with all doors closed properly - when this happens, headlights will not come on on the automatic setting, doors will not lock or unlock, either with remote or with door mounted switch, alarm will not activate, radio and interior lights will not switch off after locking car manually
Any ideas? When the door open warning disappears everything works fine, which is about 20% of the time. Getting really annoying...!
Desert Shield/Storm Vet
There is a switch inside the door on the latching mechinism. Spray some brake clean or wd 40 up inside as the switch is probobly gummed up:thumb:
Scuffy is quick:)
