1 - 5 of 5 Posts
The easy upgrades are as follows:
Head studs, turbo, new injectors and IP properly timed. You can also get a torque grind cam, and some other goodies, but thats getting in depth.
Smoke? Yes, leave it N/A (no turbo), crank the fuel up. But you can melt your motor down...and honestly it gets annoying after a while.
they have a cam for the 6.9?
Yup. Its a custom grind developed back when all the logging companies in the NW used IDI's. Helps the bottom end a lot.
i may have to look into that. i'm doing a complete rebuild of my motor and putting headstuds and and ceramic coated pistons in.
1 - 5 of 5 Posts
