1 - 1 of 1 Posts
I have tracked a issue I have been having with my 2003 F250 6.0, thought my alternator went out because it was not charging, replaced it and two new batteries, still not putting out enough volts, a mechanic told me to test the wires going to the regulator on the alt, did that and the litegreen wire was only putting out about 1 volt, the mechanic said that the instrument cluster is bad since none of the fuses were blown, they are quite expensive so i just wanted to see if anyone has had the same problem or or any feedback, any and all help will be greatly appreciated!!!
1 - 1 of 1 Posts
