1 - 16 of 16 Posts
I am going to guess so wait for someone to post instructions, but I think you use the plug on the oil cooler, and the plug on the side of the water pump.
ok i emailed him, he said he will send them right out, never did, send him an email, asking him if he sent the instructions out, never got back with me, so if anyone has the instructions please post them, or mail me the paper or something:dunno:
You just need someone to take a couple pics of what they did. It is pretty easy. I will try too but I am not going to around too much this weekend...
i believe they are all the same.
I will see if I can get some pics tonight! Didn't get a chance over the weekend!
Try this....
You might want to check and make sure you can bolt that up? If you look at my pics there is an aluminum bracket that bolts on top of the crossmember. then it bolts to the coolant filter. That threaded fitting should thread in close to the thermostat... You might need another fitting that T's into the Coolant bottle on top of the motor...
1 - 16 of 16 Posts
