you have to take the connector of on the engine side of the firewall, then take the two bolts out of the black casing, then pull it to the right a little and wiggle it around as your pulling it out.
if you had a manual you would have to take the whole bracket off with the pcm. but you don't
on the left side of the pcm at the firewall there is a lip you have to clear. thats why if you pull it to the right you will see that lip that has to clear the mount.
