1 - 5 of 5 Posts
Hi guys. I’m new with the 7.3 and it’s giving me fits. I tried installing a hydra tuner and ended up toasting the PCM unit. Sent the unit. Guy said it was unresponsive so he got a new one in and programmed it. Got the PCM back and installed. Check engine light off, WTS light cycles properly. My water fuel light is on and stays on? I crank and it doesn’t even try to fire. New motorcraft icp last. New CPS last year. Truck ran fine before PCM fried. Hooked a older snap on scanner to it with the “k20 snap on key” and it spit these codes out(pictured)
768951
Does it start without the tuner hooked up? Sure you have tunes for the right pcm code?
Sent from my SM-N920T using Tapatalk
New PCM has never had a tuner plugged into it and is supposed to programmed to my pickups vin#
Administrator
similar
1 - 5 of 5 Posts
