1 - 14 of 14 Posts
Im looking at stage 1 injectors for my 97 is there anything that i should do to my truck before this swap? and how bad is it to do this job?
intake, exhaust, gauges, chip. Not to bad of an install at all.
Do you have an auto or manual? The autos dont like to handle the added power for very long. Be ready for some tranny upgrades also.
i have a built tranny but do i need a intercooler? cuz i hear if you have stage 2s your egts get real high
what happens if i dont run one? will my egts get to high? or will i not make as much power
a truck
your egts will get high on hotter tunes and your boost will get dangerously high on hotter tunes
where is the best place to get everything for my intercooler
a truck
Id get yourself and SD intercooler used and some banks piping from banks directly
The IC reducing boost will help maintain the head gaskets and motor parts, but it in no way will save the turbo life. The turbo will see the same boost IC or not. The IC will reduce boost at the manifolds but not on the compressor of the turbo. The boost is decreased because of the air running through the IC. If your boost gauge reads at the manifolds (like it should) than the turbo is still seeing higher pressure than that.
Make any sense? The IC will not save your turbo from to much boost. Boost numbers will be different pre and post IC.
now how so you mount the ic in a obs truck is it like the 99-03s?
Shaking the Bush Boss
I'll look and see if i cant find my pictures.....
I ordered my pipes from Boyer custom truck....google search them
Discussion Starter #13
do i get the tubes off the 99-03 years? cuz i cant find any for my truck lol
a truck
yeah i guess it does but that IC is still gonna help save the turbo by lowering EGTS, thats the main killer of a turbo right there
1 - 14 of 14 Posts
