Desert Shield/Storm Vet
Im pretty sure they will fit, but you will have to reprogram your puter for those injectors im sure. One of the techs will chime in im sure:)
Have heard that the split shot injectors put a bit of a strain on the mechanical fuel pump that is found on all OBS trucks except the CA models. But there isn't a problem in programing them to run in the truck.
I own a 95 powerstroke.
Got some 02 injectors. Will they fit directly in with no problems?
Thanks in advance
Yes, you can drop them right in with no issue's. They will run just fine with your pcm.
When you put a chip on it to get the extra fuel out, you will murder your high pressure oil though.
What do you mean by murdering the High pressure oil?
I have a Canadian F-350.
THEY ARE early 03 injectors not 02, will they still work?
What year is your truck?? 03 too then no it won't murder your hpop. When he says murder tony means that it won't be able to keep up with the demands of the chip/injector combo. The hpop in the SD 99.5+ are higher volume pumps than the obs hpop.
