I need to replace my injector o rings and want to do a compression test while I'm in there. Should I check each cylinder one at a time after I replace all the o rings on 1 side or check each one as I go along. Remove all glow plugs on 1 side then check compression? I want to do this as efficiently as possible, so give me your thoughts.
