1 - 2 of 2 Posts
Its the same amount of work as putting all new injectors, so if you're in there you might as well buy new ones. There is a writeup on it in the tech section.
Otherwise if you're injectors are in good condition, just follow the writeup and make absolutely sure you get most of the oil out of the cylinders. I almost bent a rod.
1 - 2 of 2 Posts
