Hello guys,
I'm new to the forums so please bear with me. I have a reaccouring oring on my number 5 injector that keeps blowing. Its the lower fuel oring and it blows after about 300 miles of perfect, no problem starting/driving. There are no symtoms till it accually happens. Both times it has blown I was driving at 70 mph on the hwyway without a load. It blows and then white smoke and it then shutters and dies. Starting it back up is very hard and then it will die becasue of hydrolock and will not turn over again. Apon inspection the lower oring is blown and the cylinder is full of fuel. Last time dealer replaced oring and re torqued to specs. All numbers are good on the CTS monitor. SCT tune was on performance at both times of malfunction. I just had major work performed on my truck, its listed below in the specs. Thanks for any help you may offer I'm stumped and this is getting expensive.
Some specs of my truck
06 F350 CC SB FX4 Lariat; 79K on truck, new in the last 1000 miles: ARP studs; new OEM gaskets; heads redone w/ hardened seats, MBRP turbo back, cat delete exhaust; IPR screen upgrade, Coolant filter; Fumoto valve, Blue FPR spring; BulletProof EGR cooler, OIL cooler and Oil bypass filter, BilletWater Pump, 6.4 Banjo bolt upgrade, new glow plugs, 5w40 rotetilla syn, Sinister coolent bypass, FICM checked 48.5-49v, SCT X3, CTS Edge Monitor, EGT Probe, All new oil/fuel and tranny filters. I may have forgot somethings. Please help!!
