I've seen a lot of relays like that get cracked from people using pliers to pull them out. They get squeezed and can damage the internals.
Only way I could figure a cause for it, but I wouldn't think @jokester00 would be one of those people!!!!!I've seen a lot of relays like that get cracked from people using pliers to pull them out. They get squeezed and can damage the internals.
Have to agree with thatOnly way I could figure a cause for it, but I wouldn't think @jokester00 would be one of those people!!!!!![]()
Yup...finally convinced it's the IPR.You going for the IPR valve now?
Looked like a fantastic trip. Those pictures were amazing.
Did that end up being your issue? I've been fighting that for over a year, maybe even 2.....I told the shop I go to to replace it but I'm not 100% confident they did. I have a reputation for being a hypochondriac.Swapped out the IPR this morning. Nothing abnormal seen on the old one, but didn't expect to see anything either. No way to tell if it's the original from when the truck was manufactured, as I bought the vehicle used, but it's never been removed by me the whole 65K miles i've had the truck. Can you tell if it's OEM by the these numbers or is there some identifying marking on it?
It did take some coaxing. I remembered it was tight when I pulled my turbo and tried to remove it then but was unsuccessful, so I told my dad that this might end up being fun. An 18 inch 1/2" ratchet, a 2' cheater bar, and some bloody knuckles later, we convinced it to break free 🤣
Anywho...fingers crossed!
@Hydro Send me your address in a PM and I'll send this one to you for FA if you still want to look at it.
-jokester
Jury's still out at this point. Give it 6 months and I'll report back 😁Did that end up being your issue? I've been fighting that for over a year, maybe even 2.....I told the shop I go to to replace it but I'm not 100% confident they did. I have a reputation for being a hypochondriac.
Damn, my truck does this every other day.....Jury's still out at this point. Give it 6 months and I'll report back 😁
-jokester
Not like that, but wow it makes me feel better about my issue. My truck starts great and runs great. It's is only when truck is all warmed up and when I get off a freeway and sit at stop lights. The idle will go from steady, to floating up and down between 590 and about 700rpm while icp voltage and psi fluctuate with it. IPR then sits at 25-26%. Then I go a few blocks and it's back to 22% and idle settles at 635-645. You and Bismic actually tried helping me out when I first posted about it. All this time and I still haven't found it.@Tathag Your truck running like this one ?
E450TN posted this vid showing how his truck was running -- worked out the be the IPR valve
Vid Here
Thread Here
I'm not sure if my issue is resolved yet either@jokester00 Im not sure if your issue is resolved. Is your truck deleted? If not, and your issue is still happening, have a look at your EGRDC% and see what it's at when your truck acts up.
