1 - 1 of 1 Posts
i have the following codes 1272 1274 1276 1278 1294. it says the all the injectors on the driver side high to low open and the drivers side bank high is open. this morning i went to start my truck and it ran rough so i pulled it in the garage and hooked the computer up to it and it was only cyl 2 and 4 high to low open. i had an extra inj harness so i put it in. than the codes said num 2,4,6,8 high to low open. i left the valve cover and everyting off pulled it out side drove it around the block seeing if anything would clear pulled it back into the garage and the 1294 high side open bank 2 code came up along with the 2,4,6,8 inj high to low side open. all the injectors are firing on the drivers side i don't know whats going on
1 - 1 of 1 Posts
