I installed the IPR coolant filter with the manifold the other day and during test drive my deltas reached over 30. After much search I found a mention of not crossing the hoses. Ther are no instructions with the kit as it seems pretty straight foward. But the hoses go only one way. If they are crossed they won't get hot and the filter housing won't get hot. There is obviously no water flow.
The hose on the rear pipe of the manifold goes to the front pipe of the filter mount assuming you mounted the filter up. The front manifold hose of course will go to the rear pipe on filter mount.
