1 - 12 of 12 Posts
I'm going to be installing my stereo equipment in my 09 King Ranch F250 with the factory Nav unit. I need to know where the amp is for the highs and the color code/wiring diagram for it. I'm pretty sure the amp for the sub is on the enclosure, but I'd like to have the diagram for it as well. All I have been able to find is the 08 sub amp input colors. I'm pretty sure that I will need to tap into the output wires on both amps.
Thanks in advance guys!!
FYI: I will be using an Audiocontrol LC6i as a converter which will feed signal to a Punch 800a4 and Sundown Audio SAZ-1500 amplifier
Yeah it's a Turbo Diesel
I can't remember the exact site but it's 12volt.com or something like that- Rey have wire diagrams for all kinda of different systems for all vehicles- just google 12volt.com f250 stereo wiring diagram. Start there and that should get you to the right place.
Sent from AutoGuide.com App
I've done a fair amount of searching so that I didn't over post, but I've had no luck. Almost Everything on the12volt.com is about alarms. Google has been no help unless I still owned a F150 (which I have the wiring diagram for if anyone needs it).
Dang that's all they had was alarm diagrams? I've used then for stereo wiring diagrams for my 00, 05, and 08 trucks. There wasn't any with the audiophile stuff?
I went through 10 pages of search results just searching f250 on there and didn't see anything that matched. Where was the amp on your 08? Is it under the console? That's where one of them were in my f150. It was a pita to get to, had to remove the passenger seat and the entire console... I've got the next couple of days free and wanna try to get this done. I ran my 0awg power wire today before daylight was gone.
Discussion Starter · #7 ·
Thanks man. Unfortunately that didn't show any kind of diagram. It made mention of pins on the head unit and where the amp is located though
Administrator
I am throwing darts here, but is yours like this?
FYI, this install is not pretty and he have a very southern accent haha, but the info is solid.
Administrator
Discussion Starter · #10 ·
No mine is nothing like the f150. I just got rid of a 2010 fx2 which I had done the install in it. Basically all I need to know is which wires are for the highs amp. I mean, I need to know the polarity (+ and - speaker wires). I can definitely figure out which ones are for the speakers, but I have no idea how to tell which ones are positive and negative.
I don't know if your 09 is the same as my 10, but here's what I found:
LF+ white
LF- white/brown
RF+ white/purple
RF- white/orange
LR+ white/light green
LR- brown/yellow
RR+ brown.white
RR- brown/light blue
Sub+ purple/gr (my notes aren't clear if this is green or gray)
Sub- light gr/white (again, unclear if it is light green or light gray)
After wiring my truck using the outputs from the factory head unit and having it not work, I called AudioControl a few times and we determined that the outputs from the OEM head unit are indeed line level outputs. So, I had to rewire everything using the high level outputs from the factory amps. The results were worth all of the work, though...
Discussion Starter · #12 ·
That's awesome, man! I will check it out ASAP to see if those are the same wiring colors in the 09. Regardless, I sure appreciate your willingness to help!!
1 - 12 of 12 Posts
