1 - 1 of 1 Posts
IDM OHM test failure at 5.2 OHMS. INJECTORS?
Only 58,000 miles on late model 1999 7.3 manual.
The test on all circuits on injector feeds read on the very high side of passing. On the LEFT bank 3 out of 4 of the circuits are 5 OHMS.
Valve cover Harness shows no visible wear, no hot spots.
AD injectors 120V IDM. Truck barely started and when it did sounded like only a few cylinders had it running.
Should I pull one of the injectors and bench test the OHMS in the injector to verify that’s my problem?
1 - 1 of 1 Posts
