I have a 99.5 7.3 all stock engine and It use to idle up and down on warm up. I have noticed lately it does not do it anymore. What should I look for. Thanks for any help.
usaly in warn weather one its up to temp i wont do that . now in cooler weather it will go up and down to keep its temp up . if the thermostat has never been changed change it and does your temp guage work. look to see if its low norn or running hotter than normal
O i for got look and check out your exhaust back pressure valve it may be bad or the tube going to it may be obstructed and needs to be cleaned out.
In Cold weather (teens-20's) mine will idle up. Has never done it other than those really cold days, and typically in alabama huntin
