My experience with the EGR valve unplugged is no vane cycle (early 04), myself and others who have had this happen, have the VXAP2 strategy.
With the EGR unplugged in any tune (stock, canned,custom) would not allow the vanes to cycle.
The PCM needs to see the following conditions.
The PCM commands the variable geometry turbo actuator duty cycle from 15% to 85% in a step pattern to help the turbo vanes achieve full movement. Vane sweep occurs when the following conditions are present:
The vehicle is stopped.
The EGR is commanded off.
The engine speed is less than 1,160 RPM.
The engine oil temperature is greater than a calibrated value.
Vane sweep repeats approximately every hour if the previous conditions still exist. Vane sweep may occur during scan tool commanded test functions.
Even with the canned tunes and custom tunes set to EGR off, I got no vane sweep when unplugged. I believe it's because the PCM don't see a return signal from a unplugged EGR valve.
