1 - 7 of 7 Posts
i have a 2000 f350 power stroke when i started the truck it makes a louder than normally noise and when you give it a little fuel it sounds normal also running down the road loaded or not it does fine. help
I think you are hearing the turbo. I have a 7.3 that sounds like a ruff running jet at cold idle. I'm pretty sure it's normal.
it has a garreit turbo with the banks intercooler and banks 4" stainless exhaust it started after i fuled up. i have never heard this noise before. how can i check the turbo or what will it hurt and how much to fix
it is the same hot or cold it is more like a load fan turning but as soon as you touch the fuel it goes away. when you let on the fuel and stop at a red light it comes back.
1 - 7 of 7 Posts
