1 - 19 of 19 Posts
I have read on here but haven't found any definite answers so help me out please. If I have read between the line correctly the ICP pressure at idle (early 99 7.3) should be about 700 psi and at wot it should be 2400 to 2600 for ok and 2600 to 2800 for the best. This sound about right?:dunno:
My HPOP gauge on my 01 reads 400psi at idle and will spike to 3100psi before setteling at 2800psi when I'm on the pedal. Thats with a stock 17* pump, IIRC the e99 has a 15* pump.
I have a 17* from Terminator in the mail as we speak:thumb: My truck has been acting funny so I was going to get some pressure readings now and then after the new pump.
My ICP is about 600 at idle and goes from there.
Anywhere from 2600-3000 at WOT is acceptable. Your more concerned with duty cycle...
I posted about a week ago on some AE readings with no replies. My E99 ICP readings seem to be all over the place at idle it fluctuates from 461-502 and WOT i have hit high 2800's but usually between high 2400'S to high 2600's
ICP Duty cycle at idle 8.98 jumps to 9.37 with nothing in between.
I've been searching for acceptable AE Perdel readings(for all tests thus far only found ICP and Cylinder rotation)
Don't know if this helps :dunno:
Thanks:thumb:from what I have been reading your pressure is dead on!:nod:
Correct,
Basically at idle youll see around 500psi at idle.. and up to 4000psi at WOT
anything over 4000psi will pop the Valve for over pressure..
if it fails it will default to 4100 etc to allow the truck to still run..
Now the reason you see it spike is the ICP is the desired and the IPR is the regulated reading in the head..those 2 numbers have to be within so much of eachother.. at WOT 3000psi is still good numbers..thats 21 000psi fuel pressure in the cylinder lol its working great!
http://www.fordtechservice.dealerconnection.com/vdirs/vehicles/diesel/schematics/HighPressurePumpSupplementDiagnostics.pdf
have a read too..helps for diag!
Correct,
Thanks! I will do some reading on this and get back to you. I think I understand now that the IPR helps build the pressure, kind of like a fuel preaaure regulator but got to figure out how to test it now.Thats still foggy to me.
Correct,
Anything above 2600psi is fine at WOT... You will find VERY few trucks that will hit 3000psi at WOT.
Duty cycle is a mesurment of how hard your pump is working... 6% is not very hard, 50% is working hard... Anything over 60% or so is all the pump will do.
Reactions: DieselSVT
Forgive my stupidity:doh: but how do you measure the duty cycle?:dunno: 6% up to 50%?
You need some kind of a scan tool to watch duty cycle, be it Auto Enginuity or a Scan Gauge...
Here is a quick video that shows ICP and duty cycle.
Another one just sitting at idle...
Discussion Starter #14
YouTube - 54% duty cycle
I get it now! Last question, How do I get one of those gages in that video?!?! :drool::drool::drool:That would be perfect (if you can run that non stop)
Its a scan gauge. I believe some of the vendors here can get them.
And yes, its connected all the time in my truck and my wifes Excursion.
Beach Bum
ok thats the next gauge im getting. ive seen it before in person but didnt want to spend the $$$. i think i will now
at wot im not really seeing above 2700-2800. im on the te 17* atm now.
idle is in the mid 400s
oh do you have a rough idle ?
Using the Scan Guage 2 in my 2000 7.3L my ICP pressure will go as low as 445 when I let off the throttle and sometimes with light acceleration, the truck runs fine, i'm just curious if that low of ICP Pressure can hurt something?
1 - 19 of 19 Posts
