1 - 16 of 16 Posts
There's this truck I'm looking at, what do you think of the Oasis report on it?
OASIS RESULT:
1FTWW33P56EB28748
USA
EN
08/31/2009
21:49:17
FCXWS446
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
6F710D0A
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/23/2005 BUILD DATE
09/22/2005 SALE MILEAGE
00748
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/12/2009
DEALER: Caraway Ford
WARRANTY CLAIM NUMBER: 028356 ODOMETER: 090832M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 081103A 42 DOES NOT OPERATE PROPERLY
VC 7B 003 081103B
3C3Z 8575AA THERMOSTAT 003 081103C
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 081103D
3C3Z 6731AA ELEMENT ASY OIL FILT 001 081103E
XO 15W40DSD 015
3C3Z 9433AA GASKET SET-MANIFOLD 001
4C3Z 6051EB GASKET CYL HEAD 002
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
VC 7B 002
VC 8 MOTORCRAFT BATTERY 002
4C3Z 6564AA ARM-VALVE ROCKER 001
8C3Z 6565B ROD PUSH 001
XT 5QMC 001
XT 6QSP 001
IDS AND 6005 DIESEL ENGINE DIAGNOSTICS AND USING TSB 08-11-03 AS A GUIDE T O DETERMINE HEAD GASKET REPLACEMENT ON ENGINE , BOTH SIDES . REPLACE HE AD HASKETS AND REPLENISH COOLANT LEVEL
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P56EB28748
Standard Claims List For Model Year 2006
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 2 6D01 011001 5C3Z 2562901 EAB S52 30 3191
AWS Claim Key: 375601 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:0197611
Cust Comments: DRIVERS SEAT BOTTOM TRIM COVER HAS PREMATURE WEAR
Tech Comments: DRIVERS SEAT CUSHION TRIM COVER IS CRACKED AND PEELING REPLACE SEAT BOTTOM TRIM COVER
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 12 1H03 030008 * 9F452 * E29 55 26391
AWS Claim Key: 2421887 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2006 Doc #:0223131
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: PERFORM EGR CLEANING PROCEDURE , EGR POSITION TEST
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 17 7H13 120303 6C3Z 19E624 AA C20 42 35398
AWS Claim Key: 3478596 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2007 Doc #:0233532
Cust Comments: A/C BLOWS ON HIGH ALL OF THE TIME
Tech Comments: AUTOMATIC TEMPERATURE CONTROL DIAGNOSTICS TO DETERMINE FAULTY 19E624 FAN SPEED RESISTOR AND REPLACE IT
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 26 1B03 030204 3C3Z 6A642 AA D50 42 63421
AWS Claim Key: 5614300 Trx Code: E72 Labor Hrs: 10
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2008 Doc #:0256221
Cust Comments: OIL IN COOLANT
Tech Comments: VERIFY CUSTOMER CONCERN OF OIL IN COOLANT . DIAGNOSE AND REPLACE OIL COOLER ON ENGINE USING A NEW EGR COOLER ., NECESSARY GASKETS AND SEALS. COOLING SYSTEM AND RADIATOR A MESS. M TIME IS ASKED FOR COOLING SYSTEM CLEAN UP AND FLUSH
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 27 2E03 0304XX 4C3Z 9E527 AA D02 42 65210
AWS Claim Key: 5703754 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2008 Doc #:0258371
Cust Comments: WON'T START, WON'T RUN
Tech Comments: IDS AND 6005 DIESEL ENGINE DIAGNOSTICS TO DETERMINE FAULTY FUEL INJECTORS ON ENGINE # 2 ,#4,#6, AND #8 AND REPLACE THEM . ALL FOUR SHOW MISFIRE , USING IDS TO CHECK ICP. PRESSURE WHICH IS 1,200 PSI AT START UP
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 30 1H03 030008 5C3Z 9F452 AA D42 69 75228
AWS Claim Key: 6373786 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-2008 Doc #:0266171
Cust Comments: NO POWER
Tech Comments: IDS AND 6005 DIESEL ENGINE DIAGNOSTICS TO DETERMINE FAULTY EGR VALVE ON ENGINE AND REPLACE IT
1FTWW33P56EB28748 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-SEP-2005 23-DEC-2005 152082 USA 38 1A02 030102 4C3Z 6051 EB L87 42 90832
AWS Claim Key: 7987912 Trx Code: E72 Labor Hrs: 18
Dlr Cd-Sub Cd: 04510 - * Name: CARAWAY FORD Ph: 830-5822511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2009 Doc #:0283562
Cust Comments: ENGINE LOSES / USES COOLANT
Tech Comments: IDS AND 6005 DIESEL ENGINE DIAGNOSTICS AND USING TSB 08 11 03 AS A GUIDE TO DETERMINE HEAD GASKET REPLACEMENT ON ENGINE , BOTH SIDES . REPLACE HEAD HASKETS AND REPLENISH COOLANT LEVEL
Discussion Starter #2
:bump::bump:
Bump for ya!(glad you went Premium :thumb:)
Thanks!
Do you think these problems are common with 6.0's, or should I stay away from this truck?
If it was me, I'd stay away from that one. An 06 shouldn't have that many problems with so little mileage. That sucker has had the following replaced: head gaskets, oil cooler, egr cooler, egr valve, almost all the injectors, pushrods, rocker arms, and a partridge in a pear tree. LOL
It seems like it's had a pretty hard life. My 06 hasn't had any problems, other than a dirty turbo and EGR valve when I first got it from the previous owner never getting on it hard enough to burn the carbon out.
:bump::bump:
Anyone else?
:bump::bump:
Run away.......
Thats alot of stuff that went wrong. I would look for something else. Either that was a lemon or it got the sh1t ran out of it.
I agree with the others, Run away form this particular truck!
Not necessarily, I have heard of some of the 6.0s having issue because they were babied, soot builds up, among other things, and you start down that path of failures.
i dont know hell mines had 2 sets of heads 2 turbos all eight injectors and some small stuff before i got it .this spring did egr delete and oil cooler cause i was in there. and it runs like a scalded dog. so i think its luck of the draw on most of them. although mine dindt have the other problems like that one did.
Discussion Starter #14
Well, more negative than positive, so I better keep looking. Second black shortbed dually that turns out to have a bad record, this week!!!:doh:
Thanks!
most of the bad rep for these engines comes from people who tune em up (the engine is capable of 550 hp)which causes alot of damage. i think its a good engine myself althoughit does have its drawbacks(EGR cooler being the mane one) in my opinion if you were to get one leave the engine mostly stock and run the h*ll out of it!
run run run
1 - 16 of 16 Posts
