1 - 20 of 21 Posts
So i have this clunk in the drive train. I clunks when i step on it medium hard and when i let off the go peddle from any accleration. I've traced it to the T case. Ive got a Bord Warner 1356 T case. Has any one had anything like this happen? What did it end up being? Any ideas?
duct tape & zip ties
Usually when I have a clunk the first thing I do is inspect my u-joints, then brakes, then ball joints, tie-rods. Usually will find it before I have to open up the differentials.
well, ive looked @ the u joints (good) the pinion dosen't seem to have any exses play in it. and it dose it in 2 or 4 wheel drive
How did you check the ujoints
pulled the drive line off and put it in a vice, tryed movein them with a bar. no luck
If it aint a CAT itsa DOG
You could try some oil stabilizer. There could be some slop in the gears and maybe a little stabilizer would stiffin em up. I recall reading somewhere that if you have rear end noise or t-case noise it can be caused by a lack of certain elements in the oils. Just a thought.
i'll give that a try. any idea what kinda additive?
You did what! How exactly did you try moving them. They should move freely. Since you had the driveshaft out, you should have pressed the bearing caps off and look at the u-joints.
It could be your gear meshing is messed up. May need to open up the rear diff and look at the gears and check them for play.
Discussion Starter #12
My bad, thay move freely, was checkin for excess play like if thay were bad and no slop
Move onto the rear differential ;).
grease the slip joint splines! it makes a popping if theyre dry
I'm with Red, mine was clunking just like yours and stopped doing it after I greased up the slip joint.
My truck has a clunk too but my front shocks got a lot of play in them when I grab a hold of them I can wiggle them back and forth the piston is prety sloppy.
there is a TSB from Ford for this problem. The slip jonit on the rear drive shafthas to be greased. Mine had the same clunk gone now.
1 - 20 of 21 Posts
