1 - 5 of 5 Posts
im not sure what it is but latley when i take of in the truck it has a hesitation when i let the clutch out, its a new clutch and slave cylinder unit. when the truck build rpm up to about 1700 it hesitates. what do you guys think
does it do it in (n)or only under a load
nope just when you take off or sometimes when you acclerate under normal conditions, no towing or anything
if you have access to a code puller that would be my first stop.if there is no codes then i would pull the ipr valve and put new orings on it and reinstall.also make sure you have clean oil.if the ipr need orings it can miss,hesitate,and so on but will not throw a code.
ok, ill have to give that check once i get home from college next week, thanks
1 - 5 of 5 Posts
