1 - 20 of 22 Posts
I have an excursion 6.0 diesel power stroke and it won’t crank . I had a mechanic hook it up to the comp and it showed abs/brake module faulty. I really don’t want to end up at the dealer . Any assistance with this matter is highly appreciated.
wont crank = engine does not rotate when you try to start it
is this the symptom?
Get your own "scanner" so you dont needlessly throw money/parts at the problem
ForScan and the BAFX or OBDLink MX+ work well with these trucks and is inexpensive
you do not need the extended license to use ForScan -- the PC version is the most in depth, but the "lite" version will work well for troubleshooting
ABS no crank ?
Excursions have a security module and PATS key are u sure thats not the issue ?
Yes I think your right . i meant to say the truck won’t start when you turn the key . When I turn key anti theft light flashes .
You are using the key that has been starting the vehicle?
Does the key fob lock/unlock the doors?
Yes same key but the fob is aftermarket. It has an alarm system. Everything works on it but when u turn the key, it does nothing and anti theft light flashes. I had a locksmith to see if it was the key but it’s not .
The anti theft light you speak of is the factory light on the dash? (instrument cluster light and on top of the dash)
is this an aftermarket alarm or factory?
The reason I asked about the door operation earlier is because the VSM(vehicle security module) is what operates the door locks -- looks like it has power
Administrator
I think it is the PATS not letting the truck start
the remote can open the door no problem but if the PATS does not recognize the key chip it won't crank
no spare keys ?
The PATS would activate the light on the dash and the light on the sun load sensor -- was trying to determine if those were the lights or an aftermarket setup was what he is looking at
the sense coil around the key tumbler for the PATS system could be out of place or the chip in the key(rare) could have stopped working, especially if the keys are handled rough
since the door locks operate, it is likely the VSM is working
hmm -- still need to determine if the alarm is factory or aftermarket
Reactions: ZMANN
Administrator
why are we hung up on aftermarket alarms ? ( by we I mean you,,,,,, lol just kidding )
he has the pats key and the dash is " anti theft light flashes " that tells me it is the cluster display showing car padlock
that tells me regardless of the status of the aftermarket alarm the PATS is not reading the key
if it was mine i would read the pats module with my AE software to see if it has issues
worst case is have two OEM keys programmed to the module
or i think the latest forscan can do it
Administrator
this is why two keys are best and not a fan of the aftermarket ones for various reasons
"When I turn key anti theft light flashes "
I suppose it depends on where this light is located - @ZMANN
I read it as possible aftermarket, but maybe jumped the gun a little 🍺
yeah, forscan or ae should be used to read the pats system to see if it is working
would not be a good idea to try to program a key unless the system is operational
you need at least one working key todo that
forscan will do the programming
Reactions: ZMANN
Administrator
I think you can program with this PATS with 0 operational keys unlike some vehicles that need 1 non clone
the Ford dealer would have to do two keys from what i read
you would need two operational to add more keys without starting from scratch
Discussion Starter #14
Yes the anti theft light is on the dash on top.
The alarm it has is aftermarket. The door locks work , even the key pad on door works. Btw I really appreciate all the help you guys are providing!
Put the key in the ignition and turn it to the run position. Theft indicator proves out after 2 seconds and then flashes rapidly. After 15 minutes of flashing, The theft indicator will stop flashing. Within/Before a few minutes (5 I believe), after it has stopped, turn the key off and then back to run.
Discussion Starter #17
no spare key?
does it have remote start ?
finally figured out the problem . The Ecm Is burnt out. Trying to find a replacement. Any suggestions?
771077
I would look for a shorted out wiring harness in the fan clutch wiring based on the pins that look "burnt".
1 - 20 of 22 Posts
