Pull glow plugs or injectors and turn the motor over several times BY HAND ONLY untill you get the water out. Then you can spin it over with the starter. Put glow plugs back in,change all fluids, fire it up.
When you pull the plug off of the glow plug i found it easier to get a long flat tip screwdriver and gently pry it off of the glow plug connector I have done it before and it worked great
