1 - 14 of 14 Posts
· Registered
Almost new 7.3 van turbo balanced with a ww2 and in industrial injection ported shroud compressor housing .. awesome mid-top end power plus low egts i can hit 33+ psi easy with stock sticks .. this thing would probably shine with stage 1's or 2's .. great option because it can be rebuilt and its 500 cheaper then buying any basically identical drop in .. Also have a stock turbo freshly rebuilt with a stock wheel .. both have 360 thrust kits installed ...... 750 for the van and 200 for the stocker .. located near Tampa fl
· Registered
Discussion Starter · #12 ·
BUMP .. Some one is ready to step up from their stocker .. Grab just the ported housing if you want, also have a stock housing if you want to save some money
1 - 14 of 14 Posts
