Ok its time for me to replace the hubs of my truck, I want to go with warn hubs, how can you tell which ones and how hard is it to switch the out?
duct tape & zip ties
Just go to a parts store. Give them your truck info and they will get you the correct hubs.
It took me about 30 minutes to replace mine. No jacking up the truck, no removal of the tires.
All you have to is remove the hub cap, remove the snap ring, Then the hub comes off, then install the new warn hub, install the snap ring, then install the lock out part with the 7 screws.
if your wanting Warn Premiums look for part number 38826. I put them on my truck and had them on on 15 minutes.
