1 - 9 of 9 Posts
If I replace both front hub assemblies, do I need to replace the actuators for the 4wd also? I was planning on just using the old ones with the new hub assemblies
If they work, then clean/ relube and reuse.
You will want to get these: 5C3Z1K106AB (two)
If your truck has a lot of miles and never had the 4wd locks services I highly recommend getting that kit and doing a service to them.
Yeah it has 167K on it now. So ya’ll recommend the hub assembly replacement with new seals Greg mentioned above? Thanks guys
2006 F350 SuperCab, 4x4, AT, Cab & Chassis, 9' flatbed, dually, studded/egr deleted
I'm glad I came across this thread. I really need to unlock my hubs..
Is there an advantage to moving the hubs from auto > unlocked when you wont be using 4wd?
According to the driveline shop that replaced my u-joints, the city department never unlocks their hubs and they have to get new outer u-joints or maybe it was front driveshaft u-joint/cv joint every year or so.
But to answer your question - I choose to manually lock because I never replaced my auto switch because I like the option of 2LO. With the truck in AUTO and unlocked, than they are unlocked. Unlocked hubs mean the front axle shaft isn't turning, therefore less wear on the u-joints on the axle and the front driveshaft.
Administrator
it is easy to reach in and see if you can turn the axle shaft at the u joint ( knuckle area) check both sides occasionally and this will let you verify your hubs are locking and unlocking properly
1 - 9 of 9 Posts
