So, I did the high pressure oil crossover install yesterday. In the first startup after install I found I didn't have the connections tight enough and squirted oil all over the engine bay. Using a spray degreaser I cleaned up everything, wiped down, and then used a spray bottle with hot water to clean off the degreaser. So, tightened the HPX connectors on the new line and a cleaner bay I started it up and the HPX was not leaking. I gave it a few minutes to idle and backed it up to clean the mess on the ground, I walked back to the truck and noticed a dripping that turned out to be fuel. I looked under and there's what appears to be an "overflow drain tube" at the bottom of the truck dripping diesel fuel. I took it for a ten minute drive and it is still dripping.
It was not doing this before the install. Is this just the ECM relearning or something? Has anybody else seen this?
Those are great ideas, thank you both. I cycled the valve open and closed and will see if that clears up the issue tomorrow. If not, I will checkout that o-ring kit.
Thank you again!
