1 - 15 of 15 Posts
i replaced the hpop on my buddies 02 7.3 i got everything put back together...when i removed the fuel canister i drain it and cleaned it got it all back in and now i cant get it to pump fuel into the canister...i was wondering if i had to prime the pump by filling the canister back up any ideas,,,i did it on my old truck but it was a couple of years ago...any suggestions...also i think the relay closest to the the cab gets real hot when the key is in the on position...
yup you should prime the system. i think its 3 quarts
its not picking up fuel to pump into the canister where the fuel filter/water seperater is...
sorry i messed that up. i thought we were talking about the HPOP reservoir. did you cycle the key numerous times?
yea it was gargling i tried to put my finger of the whole the put some back pressure,,,its building air pressure but i cant get any fuel..thought maybe if i poured some diesel into the canister maybe it will prime up...
it should be pushing fuel though. how long did you leave the key on?
about 30 sec each time...
it would quit gargling...
sounds almost like hes out of fuel. check that?
says he is sitting on half a tank ill tap on the tank tomorro see if i can hear anything my dad 06 fuel gauge sticks on him all the time...but i do no that when i removed the fuel filter before taking everything apart it had fuel in the canister.
when i did my HPOP i had no problems. i thought there was check valve in the pump :dunno:
Discussion Starter #12
well appreciate the the help...i can say this is one of the things about my old truck that i dont miss,,,
Discussion Starter #13
well got her runnin fuel gauge was stickin...
anytime... believe me i know. kinda wish i would have bought a cummins. with the amount of money i spent dealing with getting fuel an oil sucks. . . but im in too far now cant look back :evillol:
so it was out of fuel? i hate when its something simple. . . been there done that too many times.
Discussion Starter #15
yea...everytime lol
1 - 15 of 15 Posts
